Old 03-11-2003, 06:38 PM
doug294 doug294 is offline
Send a message via AIM to doug294
Question Vtech head? Hydro tranny?
Will a 2000 SOHC V-tech head fit on my 91 civic hb block? Both are D series? Also will the hydro tranny bolt up?
Old 03-11-2003, 06:41 PM
91zc 91zc is offline
The head will bolt up but you will need to make a few mods for it to work properly. The trans will bolt to the block but you will need to custom make a transmission mount and bracket for it to bolt to the chassis. Plus you will need a newer clutch kit from the 2000 model to mate to the transmission year since the input shaft on the trans has a different number of splines than a disc on the early 88-91 civics. The head swap would be worthwhile but the trans is more work than it is worth.
91 civic 4dr
b16a
14.8@94
Old 03-11-2003, 06:46 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
i dunno about the head swap part. it never turns out reliable. it's cheaper to drop in and 100% more reliable to go sohc vtec or a dohc zc.
i agree with the trans. way more trouble than it's worth. the best trans to use would be 88-91 Si/EX. i do believe the EX trans (if you can find it MT) has a longer final drive. not much....but if you're picky, its worth looking into.
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 03-11-2003, 06:49 PM
True true. The head swap can be reliable if done correctly thought. Most people just half ass it. But like Ami said you might be better off investing in a full swap since they are dirt cheap these days.
91 civic 4dr
b16a
14.8@94
Old 03-11-2003, 07:01 PM
What mods?
What kind of mods are we talking about?
Old 03-11-2003, 07:05 PM
amy@af's Avatar
Re: What mods?
too damn much. the zc can be found for $500 or less. you can find a 92-95 Si/EX d16z6 for $250-500. i got my 96-00 d16y8 for $500 (with only 12,000 mi. out of '00 EX) my y8 was a killer find. you can generally find them $500-900. as 91ZC said....they are just so damn cheap anymore the mini-me monster isn't worth it.
Old 03-11-2003, 09:29 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Re: Vtech head? Hydro tranny?
The least you could do is spell it right :finger: :finger:
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
