Old 08-07-2008, 06:53 AM
shyekiera shyekiera is offline
alternator
Can anyone describe to me where the alternator is located and how to take one out to replace it?
Old 08-07-2008, 07:00 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: alternator
Assuming you have a 6 cylinder engine, it's the top- and rear-most belt driven accessory.
More info (year, engine) would be nice.
My initial reaction is to tell you if you can't identify it, you might not wanna fool with it, but I'd be glad to help if you are determined to do so...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 08-07-2008, 07:32 AM
Re: alternator
not sure about the engine, but can check. 1998 is the year sedan 4 door
Old 08-07-2008, 10:45 AM
j cAT j cAT is offline
Re: alternator
IF you don't know what an alternator looks like I don't think you should do this....
what you must do before you do anything is to remove battery and fully charge battery...
then with a repair manual for your vehicle attempt to remove and install the alternator by following the instructions ...you may have problems because you may not understand the terminology but here at these forums many will help you understand these things...
Old 08-07-2008, 11:01 AM
Re: alternator
You'll need a way of supplying some power to the ECM while the battery is disconnected too, or you'll blow the idle memory and the car will act goofy after you're done.
I use a battery charger hooked to the cables but you have to be careful...any time you mess around with a newer car's electrics is a good opportunity to wipe out the electrical system...then you're really screwed...
Just getting to the battery cables on a Lumina is a pain....
...empty gun rack.
Old 08-07-2008, 07:22 PM
Re: alternator
the power must be removed when replacing the alternator...if you short out the battery power a surge could wipe out the vehicle electronics...
relearning is not a major problem...electronic system controls are ..
remove the ground to the battery first then positive...
Old 08-07-2008, 08:01 PM
Re: alternator
I've seen people use a 9v battery to keep the ECM alive while removing the risk of a zorch...
I should clsrify, I use a .5 amp charger that is a maintainer charger for motorcycle and other small batteries. It has polarity and overload shutoff, and doesn't push enough power to really hurt anything if there was a whoops...and shuts down instantly.
...empty gun rack.
