Old 08-06-2008, 08:19 PM
hondalegend hondalegend is offline
headlight turn signal trouble
I went to change out my gauge cluster to a canadian one and only one headlight comes on now it stays on bright even on the cluster. my turn signals work but when io cut my right one on my left corner blinks too. i even changed the turn signal and headlight switches and put the original cluster back in but no luck.and i have tried the ground coming off of the cluster harness.
Old 08-06-2008, 08:38 PM
dan89 dan89 is offline
Re: headlight turn signal trouble
did you check fuses?
click for my cardomain ^
Old 08-06-2008, 08:44 PM
Scrapper Scrapper is offline
AF Premium User
have you tryed reseting your computer?
Old 08-06-2008, 08:52 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Computer won't have anything to do with his headlights and blinker, so completely ignore that post.
Sounds like a bad ground to me, usually something random and crazy like that, its a ground. Start checking your grounds.
You can also install your other gauge cluster again and see if the problem goes away, then you know its in the cluster. But still sounds like a ground issue to me.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-06-2008, 09:53 PM
AF Premium User
so computer dose not tell your lights when to come on and when not to you say? then why dose it have a computer? because computer runs your whole car.so maybe i behind in time.
Old 08-06-2008, 09:58 PM
Tony's Avatar
TLD Member #1
No, your headlight switch tells the headlights when to come on or off. I don't know about these newer cars what know when its dark outside, or daytime running headlights, but on our cars, its only the switch.
The ECM doesn't control everything our cars do, mostly anything that is related to the engine, everything else doesn't need a computer to tell it what to do. A lot of it is just relays.
Granted, the newer model cars usually have a computer for just about anything and everything, but we are not talking about newer cars.
Tony
Old 08-06-2008, 10:08 PM
AF Premium User
oh i see on newer cars. i never relized this was that old so i better pay more att on the year.thanks for corecting me..
Old 08-07-2008, 03:20 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
While there are several newer vehicles which use modules to control most everything, including lights, these days, the average vehicle still uses plain old relays to control lights and other things.
Just for future reference.
Old 08-07-2008, 09:19 PM
AF Premium User
yah like my 79 malibu it's still stock 229 i mess with them every once and awhile. i call auto zone say i need dist cap for that year 79 and they don't have in that year so i tell them to try a 1980 because this 79 came out with the chevy moter and they all switched to a 231 buick..but yah tell them to pull one out of stock then you'll the socket there to fit it...
Old 08-08-2008, 02:36 PM
Does that post make sense to anyone else?... I have no idea what this guy is thinking... but it's completely OT, as far as I can tell... and definitely not understandable...
Old 08-08-2008, 06:24 PM
amen brother
Old 08-08-2008, 07:48 PM
AF Premium User
Question Re: headlight turn signal trouble
i have no ideal how this got in to this post? sorry about the confusion wont happen again..sorry to all of you.
Old 08-09-2008, 08:06 AM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
im curious how u madeout with your problem? Tony had good advice about switching it back to your orginal switch did it work for you? keep in mind if u post a thread it be cool if u cameback to let us know of your progress so we can keep troubleshooting with you as for u other douche bags that posted in here with WORTHLESS post..take anything not thread related to the O/T section
Old 08-09-2008, 07:00 PM
hahah... he quoted my post to say sorry... wow.
Old 08-10-2008, 12:40 PM
ok then kiss my lilly white ass. oh you probably kiss ass as far as you got???
Do things like this get you far in life? I wouldn't know.. I don't do it... I do know one place it will get you... ignored, temp ban, then eventually banned permanently.
So, please... In the interest of all of us not really caring what bad choices you make... keep stuff like that up.
