Turbo?
I am very new to turbos. And I have a lot of questions regarding them. Do I HAVE to increase the compression of my engine to add a turbo? And is there a specific type of turbo that I HAVE to use with my car? I have 1978 plymouth Volare with a slant six(225) in it.
Re: Turbo?
Basic Turbo 101:
A turbo charger uses waste exhaust gases to drive the impeller of a pump that increases the pressure of the intake gases going into the cylinders. The increase pressure in the cylinders from the turbo act like a temporary increase in mechanical compression ratio when under boost. Do you HAVE to increase the mechanical compression ratio before you install a turbo charger? NO! Keep it the same or even decrease it a little if you want. Remember, the higher your mechanical compression ratio, the more stress is placed on the internal engine parts when a turbo is installed. Changing (decreasing) the mechanical compression ratio will require either installing a new head with larger combustion chambers or installing new pistons with concave dishes in the top or decreased deck height. Either way, decreasing or changing the mechanical compression ratio will require significant engine work. I have not heard of anyone installing a turbo charger on a slant 6 before, but I am sure it has been done. Do research with after market turbo manufacturers to find the right set up for you.
"This car may be old, but it will still climb Kirker Pass at 110!" 1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible |
Re: Turbo?
Thank you so much for you help. But I have one last question. Would decreaseing the engines compression help a lot in horsepower, engine life, or both?
Re: Turbo?
Lowering the compression ratio will decrease the power output, lower combustion chamber temperatures, put less stress on the components and make it easier to run on regular gas. Raising the compression ratio will increase the power output, raise the combustion chamber temperature, put more stress on the components and require premium fuel.
