Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 08-06-2008, 02:40 PM
oldmerc oldmerc is offline
1989 Mercedes 190 e wont start
Any help would be appreciated, my 1989 190e refuses to start, I replaced the ignition coil and the crank shaft position sensor, but still it won't start, the fuel pump sounds like it is priming when i turn the ignition key. It also does not seem like i'm getting any spark when i pull the coil wire and turn the engine over. Does any one have any suggestions??? Please???
Old 11-30-2009, 10:19 PM
yanceycat yanceycat is offline
Smile Re: 1989 Mercedes 190 e wont start
Hi did you fix your 190 yet I can't help much but my 190 is doing the same thing, Check the ovp relay it in back of the batt it a small box with a fuse in it if the fuse is good check voltage at pin 30 this is alway hot and pin 15 hot with key on only pin 31 is neg there a pin layout on the relay, this is all I know hope it help
Old 01-02-2010, 03:51 PM
DonWontheLibra's Avatar
DonWontheLibra DonWontheLibra is offline
check your ignition module located on the driverside.
