Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 08-06-2008, 10:22 AM
wirewheel99 wirewheel99 is offline
Gearbox R&R
Can the gearbox be removed and replaced by removing the tunnel housing and going the inside of the car with out removing the engine?
We had a gearbox that suddenly had a nickel size hole in the side!
I will let you know what happpened, complete with pics, once we get it out.
Thanks
James
wirewheel
Old 08-06-2008, 11:31 AM
Gatorac's Avatar
Gatorac Gatorac is offline
Re: Gearbox R&R
Thanks
James
wirewheel
Take the tunnel out and the trans will come out easily. Leave the tunnel in and you'll have to pull the engine. I've done it and have the scars to prove it.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 08-06-2008, 12:38 PM
eric1h eric1h is offline
Re: Gearbox R&R
can't you just remove the 4 bolts that connect the gearbox to the bellhousing, disconnect the UV joint and the tranny mounts and pull it out that way? The actual gearbox should just pull out and drop down.???
No?
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 08-06-2008, 12:44 PM
Gatorac's Avatar
Re: Gearbox R&R
Originally Posted by eric1h
can't you just remove the 4 bolts from the bellhousing, disconnect the UV joint and the tranny mounts and pull it out that way? The actual gearbox should just pull out and drop down.???
No?
No. Try if you like. We all learn from mistakes. They don't have to be our own mistakes. The trans will not pull far enough back to get the input shaft clear of the bell housing. There's 4 bolts to remove the tunnel. Remove it.
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Old 08-06-2008, 12:46 PM
Re: Gearbox R&R
interesting, and good to know! I wasnt aware that it was that easy to pull the tunnel.
Old 08-06-2008, 12:58 PM
Re: Gearbox R&R
Thanks for the info. we will post pics and details as we bloody our knuckles.
James
wirewheel
Old 08-07-2008, 07:01 PM
mhowington mhowington is offline
Re: Gearbox R&R
No?
If you had a miracle you might possibly be able to pull that off, but highly doubtful. Besides, putting it back in would be more difficult in terms of getting it lined correctly to just simply slide in. (there may be a bit of sarcasm there).
Old 08-07-2008, 07:58 PM
Re: Gearbox R&R
Thanks
James
wirewheel
Yep, just disconnect the battery and gently move the console over to the side. Take the housing off and you should have enough room to manuaver and such.
