Go Back   Automotive Forums Car Chat > Buick > Regal
Old 08-06-2008, 10:07 AM
woodmen's Avatar
woodmen woodmen is offline
94 regal custom horn wont turn off
I understand the problem is in the stering wheel ? Their is an air bag in the center ,this is a concern, what do you do to get the stering wheel off to fix this problem?
My avatar is a wood boat I made with a 650 kawasaki jetski .
http://s147.photobucket.com/albums/r...os/TNT%20boat/
The closer one comes to the truth, the more he is approached by a lie infowars.com
Old 08-06-2008, 10:18 AM
corem corem is offline
Send a message via MSN to corem
Re: 94 regal custom horn wont turn off
First disconect the battery and give it ten minutes to lose charge to air bag system. Then on back of steering wheel there should be two ten mm bolts tto remove airbag unplug the connnector to airbag and hook back up battery this will tell you if it is in the horn bottons in air bag. This will alo tell you if the problem is on down in the wiring. Make suree the battery is dissconected to reinstall drivers airbag! The parts that could go bad are airbag and the clockspring wich is under the airbag.
