Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 08-06-2008, 07:11 AM
dirtdriver11 dirtdriver11 is offline
fuel pressure
what is the required fuel pressure for a 93 bonneville? mine pumps up to 42 psi and then drops down to 39 to 40.
Old 08-06-2008, 03:37 PM
maxwedge maxwedge is offline
A990 racer
Re: fuel pressure
39-40 running I assume? If so you are ok.
Old 08-06-2008, 06:02 PM
Jrs3800 Jrs3800 is offline
Re: fuel pressure
The 93 Tuned Port Injection 3800 should fall into the 41-47 PSI range...
Was the car idling at 39-40? Or was this with the ignition on for the fuel pump prime? If it was this would be considered normal... If you were to disconnect the Vac line to the Fuel Pressure Regulator and it stayed at 39-40 instead of increasing then there may be an issue someplace...
