Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 08-06-2008, 12:58 AM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
Serpentine Belt on a Jetta V6
A guy at work told me he needed it replaced on his 2001 (or 2003) VW Jetta V6 by a mechanic I told him to buy the belt and do it himself and save the cash.
He's afraid he might screw it up so he asked me to do it for him. I've never worked on a Jetta before so I was wondering if the procedure is the same (loosen tensioner, remove and replace belt) as domestics vehicles or do I need any special tools or procedures to get the job done right.
Also, he offered to pay me, so how much will it be fare to charge for this? His Mechanic wanted $150 and I was thinking smoething like $30 but not sure...Thanks for any help
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 08-06-2008, 09:50 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: Serpentine Belt on a Jetta V6
replace the tensoiner (95.00 ebay) at the same time as the belt (40.00 dealer)
Its quite simple, cut the old belt, remove the 3 10mm bolts that hold the tensioner to the head. Install new belt (make sure you put it arround the crank first, it has a lip and a bolt at the back that the belt catches on some times). install a M8 x 80 bolt into the new tensioner and tension it down and bolt the tensioner to the engine. after the new belt is on remove the bolt to put tension on the belt.
Shouldnt take more than 30min to do. Dont do just the belt because the tensioner WILL fail w/in 6mo and take out the new belt.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 08-06-2008, 10:01 PM
Scrapper Scrapper is offline
AF Premium User
just curious why you want them to buy new tensioner?
Old 09-20-2008, 11:30 PM
New2GasEfficiency New2GasEfficiency is offline
The tensionor will go out, last year i replaced my belt with a fancy expensive one so i wouldnt have to mess with it again any time soon. 3 weeks later the tensionor failed while i was on the highway causing the belt to fray into about 10 different strands causing a real mess. i had to take 2 pulleys off just to get all the mess out. i replaced everything and soon after my water pump went out. so if your over 75,000 miles than a new water pump wouldnt be a bad idea either. but that would take a whole day. dont mean to scare ya just warning you.
