Old 08-05-2008, 10:09 PM
GoBears's Avatar
GoBears GoBears is offline
Fuel capacity wrong
When I let my gas run down until I get low fuel warnings on the dic and on the gauge, it only will take about 13 gallons until it is filled. I can actually hear it coming up the tube so I know its not a false full. Everything seems to working perfectly as far as the dic is concerned, just that all the mileage adds up to me having a 14 gallon tank. Is there a way to reset the real empty or do I have to replace parts?
Thanks all
GoBears
2000 Pontiac Grand Prix GTP
Old 08-05-2008, 10:18 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Fuel capacity wrong
Was the fuel pump assembly or fuel level sending unit ever replaced. It sounds like the fuel level sending unit is out of calibration which probably explains the discrepancy.
Also, when the low fuel level first comes on you will have a few gallons left in there.
The gas tank capacity for 2000 models is 17 gallons.
Timeslip 08/12/06
AF Community Guidelines
Old 08-06-2008, 07:03 PM
GoBears's Avatar
I have no idea if anything was replaced I just bought it 2 weeks ago. Is this something I can fix cheaply or should I just deal with it? Thanks for the quick reply man.
By the way, that timeslip is pretty impressive. What mods u got?
GoBears
Old 08-07-2008, 07:50 AM
BNaylor's Avatar
There is a check you can perform with a digital mulitmeter (DMM) where you check the resistance specs of the level sending unit at low, medium and high points of the float. If off then you bent the float arm to adjust it in. But before getting to that I recall I have around 2-3 gallons of gas left when the low fuel indication first comes on. This is normal for reserve fuel.
The mods are listed at Dragtimes.
Timeslip 08/12/06
Old 08-08-2008, 01:21 PM
troy1 troy1 is offline
AF -Advisor
My GP is the same way. 12 gals DIC chimes, 13 gals low fuel light comes on. The most I ever filled up with was 15 gals.
Old 08-09-2008, 09:13 PM
GoBears's Avatar
That's exactly what mine does too. My biggest fill up so far... 13 gallons and that was gurgling coming up the fill tube heh. It's averaging 23 mpg every tankful so I'm pretty happy with that.
GoBears
