Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-05-2008, 05:34 PM
akrob85 akrob85 is offline
engine problems
i have 1994 firebird formula1 with the LT1 it was parked for 2 year due to distributor problems i fixed that and then replaced the sprak plugs and wires now when i start the car it ildes rough but when put it in gear it bogs out and acts like it wants to die out and shakes real bad at low rpm but when when u get at higher rpm it shakes a little bit but dosent have the power that it should have what should i do to fix this problem ?
Old 08-05-2008, 07:43 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
Re: engine problems
did you make sure to put the plug wires back on in the correct order?
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 08-17-2008, 04:42 AM
5046adam 5046adam is offline
Re: engine problems
did u leave gas in there for two years too. if so drain gas, put clean gas. next take off the air inlet tube at the throttle body and clean it real good with carb cleaner if u can't you will have to take it off and clean it u will need a new gasket also. prob be good idea to change fuel filter too just a thought. hope this helps
