Smallest enclosed trailer to fit these cars?
Any of you using an enclosed trailer? if so, whats the smallest you've used? been lookng at either an 18x8.5 or 20x8.5, but want the smallest trailer I can comfortably fit the car in. trying to save on weight and gas mileage!
Thanks
Eric H (in case you couldn't guess) GT-WC #22 (now #62 and Blue) |
Re: Smallest enclosed trailer to fit these cars?
I'd say go with the 20'. You gotta leave yourself some room to strap it down!
I have a 20'. There's room for my tool chest in front of the car. You could get away with an 18' if you don't plan on putting anything but the car in the trailer.
Check your axle capacity and trailer weight prior to purchase. Mine wieghs 3900 lbs. If it had the standard 3500lb axles, it would only leave 3100lbs for the car and cargo. Go for the 5k lb axles.
Have Fun Jim Pomroy 96 Miata track car. 2012 Camaro SS. Backdraft Racing Cobra #930 92 Miata "LemonDrop" ![]() Saturn V Rocket Miata Crapcan #81 99 Miata daily driver. |
I would not go with anything less than 24 foot. There is little resale value in the small units because of the lack of room. You can not drive the panos into the trailer so you need room for a winch to pull it in. I have 3" on each side between the wheel wells going in forward and you need a lot of room to tie the front down. I don't want to sound like doom and gloom but in this case longer is better. Look for a good used trailer w/7000lb axles and you won't have many problems. As a side note my Panoz won't even fit on my alum trailer |
Squerly |
I have a 20' trailer that has an extra 3' for V-nose. The size is perfect for my use. I drive my car onto the trailer with no problem - just someone to line me up.
Jim McGovern ~ Building 289 Lemans Replica ~ '92 Mustang Coupe: 347ci / Carb Pictures |
I have a 24 ft trailer. Plain-Jane white with a side door. I too drive the Panoz on and off the trailer without too much trouble. A guide is great, especially for going into the trailer. You do have to get out of the car like the NASCAR boys. Climbing out the window is always an agility test.
I like the extra 6 ft of room in front of the car for extra wheel and tool storage. The car is soooo low that I had to make a set of 10 foot ramps to get the car on and off the trailer without dragging the front air dam. I picked up the trailer used. It's a 10 yr old Haul Mark. It took a little TLC, like painting the floors and doors, but it was one third the cost of a new trailer. Check the electric brakes if you buy used. Make sure that they have been maintained properly, and that the emergency brake system works.
Jerry 1999 Panoz GT-RA |
One the car is unloaded, and you have driven back off the ramps, put one of them behind one of the trailer tires and the other ramp in front of the other trailer tire. This keeps the trailer from rolling around if the parking space is not exactly level. Unhook the trailer and your done!
Squerly |
(old flying habit, I cringe as most people dont use them!). Ive also toyed with a way to secure the tydex, but be able to move or remove it for loading as thats usually a major problem as well. However... in the dark places of my lab ive still not had a light bulb go off.
Hey Eric:
I just talked to Steve and he said "they" (not sure who they are) made a 16' that allowed enough room to haul the car and secure while it transit. Ill try to get more detail. However, I agree with the other replies, although it would help the personal economy and the envrionment, you still want to go a bit bigger to have a little wiggle room. |
My suggestion for top quality enclosed trailers would be: GoldRush Trailers (goldrushsales.com) and Tommy's Trailers (tommystrailers.com). I've owned trailers from both of these Folks and they each build a very nice trailer... extremely strong and good resale. All aluminum as well.
I'd go at least 20' but 24' will give you the extra room you'll need for tools, parts, tires etc. The rubber torsion suspension on Tommys Trailers gives your car a great ride, much better than the standard spring ride most other builders use. I pull our Tommys Trailer behind our Bus at 70 or 75 without a problem. |
