Old 08-04-2008, 10:27 PM
robc133 robc133 is offline
A/C blows warm on Drivers side-1999 Buick Park Ave Ultra :-(
Hi, I have a 1999 Buick Park Ave Ultra with the supercharged 3800 Engine. About a month ago, I noticed that my climate control listed the outside temperature between 140-150 F, the actual outside temp was probably about 80-85 F. Everything else was working fine. Today when I put the Air Conditioning on (at any low temp setting), the two vents on the passengers side blew out nice cold Air Conditioning, the two vents on the drivers side blew out heated air. I tried a few different things such as trying the unit on all possible settings, fooling around with the passengers temperature mixingslide bar, shutting system (and car off and on), i even disconnected the negitive side of the battery, hoping hat something would reset, no luck. It still blows hot air on the drivers side. Thanks for any sugestions!!! Rob
Old 08-06-2008, 06:13 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: A/C blows warm on Drivers side-1999 Buick Park Ave Ultra :-(
More than likely, you have an actuator problem as discussed in this thread: Click Here
BTW, you should replace the external temp sensor. It is located in the front grill area.
