Old 03-11-2003, 04:53 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
Question B18C1 motor buildup
okay, so I'm rebuilding my motor starting friday and so far this is what I plan on doing, just wondering if anyone out there has any suggestions on what else I might consider doing... JE pistons (9-1 ratio), new rings, eagle rods, new valve springs and retainers, boring it out, port and polish, titanium sleeves, new cam gears and shafts, new clutch, lightening the flywheel, new throttle body, 550 cc injectors, new motor mounts, (possibly an intake manifold but probably not til later)... fyi, building it up for turbo application. Thanx in advance for any suggestions.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 03-11-2003, 06:53 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
how much are you spending on that build up for everything ?
Team Lonely Drivers
Old 03-11-2003, 07:41 PM
seth 90DX/ZC seth 90DX/ZC is offline
Banned
JE's suck ass. I got some Go with endyn there's are a little more expensive but are worth every penny. BTW if you plan on goin past 12 Psi you might want to sleeve it! I would just spend the 2K on a dart block if I was goin FI.
Old 03-12-2003, 12:49 PM
zippeay zippeay is offline
If you plan on boosting a lot which I'm assuming you are since your doing all this get a double thick head gasket just in case, wouldn't hurt. Sound like you'll have a kick ass motor when your done, post some pics when your threw. The Dart block is $2,000 damn thats expensive
Old 03-12-2003, 02:11 PM
i would have suggested a jg block, idk how good dart is
Team Lonely Drivers
Old 03-12-2003, 07:22 PM
funkdaflex1 funkdaflex1 is offline
u should get all new underdrive pulleys if u havent yet and all new fuel system ( fuel regulator, rail, filter) but thats not really internals what ur lookin for and def a new new or upgraded ecu sounds like u could use the aem engine management. just puttin in my 2 cents and seriously how much are u paying on this build im very curiouse.
Old 03-13-2003, 03:37 PM
casperGSR's Avatar
thanx for the suggestions guys... as far as how much am i spending I'm looking at around 2,500 to 3 g in parts... as far as labor and machine work I'm not quite certain yet cause it's getting done at my buddies shop so I'm not sure what he's gonna charge, on top of it I'll hopefully get to do some of the work myself with him to speed up the rebuild, all depends on how much time i can get off work.
Old 03-13-2003, 09:06 PM
umm idk if a bore of the block is a good idea if yoru turboing, i mean if your gonna turn it into an all out racer yeah ok. but thats my opinion
Team Lonely Drivers
Old 05-15-2003, 12:19 PM
hcar hcar is offline
I would put the injection system from TWM Induction on that puppy
www.twminduction.com
Old 05-18-2003, 01:11 AM
ssshhhh (_burn_)'s Avatar
ssshhhh (_burn_) ssshhhh (_burn_) is offline
Send a message via AIM to ssshhhh (_burn_)
twm .....thats individual throttle bodies dumbass. hes building a motor for turbo. read before you post. stop destroying bandwidth
6.7 @ 211mph whooping kubo's ass all over the track
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
