Old 08-03-2008, 10:47 PM
doctor_x doctor_x is offline
2001 Silverado 5.3L Z71
A little help please. My 2001 Silverado 5.3L 4x4 Z71 truck has been running perfectly until today. I went to the store after shopping I went to start my truck, it turned over drove for about 100 yards and it died. Attempted to restart. It would turn over then die after a few seconds. I tried to push on gas however it would not seem to make a difference. I replaced the battery thinking this may have had someting to do with it however it made no difference.
Old 08-04-2008, 10:40 AM
j cAT j cAT is offline
Re: 2001 Silverado 5.3L Z71
why the battery???
anyway if you look up your issue here at the forums you will quickly lean that the fuel pump is a common problem especially with owners running on empty.....
fuel pump pressures are needed ....then it goes into other areas....spraying the intake on engine with a small amount of gas if it starts this then increases the likely hood of fuel supply issues...
