Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-03-2008, 08:19 PM
ctabacchi ctabacchi is offline
Question 98cv front suspension
I just replaced the rear coils, rear shocks, front coils, and front shocks. I have 300lb rear coils and KB shocks. I planned on and did a fair amount of towing and the rear end doesn't sag when any weight is put on it.
However, I put stiffer springs in the front, 1050 or 1100. I knew they were shorter than stock and have no problem with that, but the front end bounces like crazy, the new shocks are also KB.
Is it because the rear is so stiff or that the shock doesn't get to travel its full length or both.
I'm ready to install the stock springs back into the front. The heighth is not a bifg deal for me. But i would like the ride to be stiffer in the front.
Any suggestions?
Thank You.
Old 08-04-2008, 06:27 AM
rhandwor rhandwor is offline
Re: 98cv front suspension
They used to sell shocks with a small spring around them which help somewhat. You can also check if air shocks are available.
I would check if any parts stores handle a heavier spring the correct length.
If you have any spring shops in your area ask them.
Old 08-08-2008, 09:28 AM
Stick462 Stick462 is offline
Have you checked your new shocks again /there my be a bad one from the supplyer .It happens / how shorter are this new springs?? 1 inch wont make a difference. You could try CVPI springs (cop car ) Shocks control the bounce/springs cause the bounce unless the coil spring is binding????
Old 08-08-2008, 05:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Monroe makes coil over shocks for the CV. We use them on the Police vehicles to help in handling. With KB shocks, the original coil springs should work well.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
