Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-03-2008, 05:38 PM
eclipse787 eclipse787 is offline
Confused about the fpr
What exactly is the fpr regulating the pressure coming from the fuel pump going into the fuel rail, or to keep the pressure high and regulate from the fuel rail back to the tank?
Old 08-05-2008, 02:16 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Confused about the fpr
The FPR regulates pressure at the regulator and back toward the pump. In other words, everything from the pump outlet to the FPR is pressurized. From the FPR outlet, excess fuel (fuel pumped up to the rail but not consumed or required to maintain pressure) is sent back to the tank at low pressure. We only care about fuel pressure in the rail/at the injector and that is what is regulated. Hope that clears it up.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-06-2008, 01:12 PM
thanks that makes sense now. so then how much pressure can the seals on a 95 fuel rail handle? if im running no more then 7 lbs of boost about what pressure should i have it set at?
Old 08-06-2008, 02:41 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Turbo or non-turbo stock model?
Stock fuel rails will hold up to ALOT of pressure. That's what they're built for.
On my car (95 ESi n/t converted to turbo), I run 7psi also. I have a 12:1 FMU controlling the pressure. Idle, fuel sits at ~40psi. When I hit boost, for every 1 psi I get, the FP goes up 12psi. So "what pressure" should you have it set at, doesn't really make sense unless you're talking base idle FP.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
