Old 08-03-2008, 05:27 PM
skynyrd7569 skynyrd7569 is offline
97 GT engine squeal
I have an engine squeal coming from my Gt when I let off the gas and coasting to a red light. It only seems to happen after driving for awhile. When I tap the gas it stops, and does not do it under power. I have tried turning off the AC and this does not make a difference. I just replaced the belt and idle tension pulley not to long ago. Any suggestions.
Old 08-04-2008, 04:08 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 GT engine squeal
Have you recently replaced the PCV valve, and if so, did you remove the o-ring from the old one and reinstall it on the new one? If not, they will whistle under high vacuum situations.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 09-09-2008, 08:04 AM
Any other suggestions, this noise is getting worse, last night I could hear my wife coming down the street. I just changed the PCV valve and I did not see any o ring on the valve its self. I did notice the MAP sensor is a little loose, 2 of the locking tabs are broken (one on each side).
Old 09-09-2008, 09:32 AM
JonJon68 JonJon68 is offline
Send a message via AIM to JonJon68 Send a message via MSN to JonJon68 Send a message via Yahoo to JonJon68
I suggest that you re-read what Rich wrote. You need a rubber o-ring on your PCV valve. You can purchase a new PCV valve kit at your local dealer for around 20.00 bucks. It includes PCV valve, o-rings, and a new MAP/PCV bracket that will help to keep your MAP sensor seated tight. You may have two vacuum leaks, one at your MAP sensor and at you PCV valve.
1997 GPGT 3.8 Dark Teal Metallic. 222000
4 door sedan
No Mods
Old 09-09-2008, 04:07 PM
Thanks, I went today and got the PVC kit for $27 and some change. The MAP sensor holder is a different style but it will fit, it also came with a spring that sits on top of the PVC valve. I will let you know if this works.
Old 09-09-2008, 04:36 PM
Yes, I had the older style also and no spring. The new kit included all of these. Even if this doesn't fix the noise you described, you needed these new parts, o-rings anyway. Good luck and keep us informed.
4 door sedan
No Mods
Old 09-09-2008, 11:37 PM
wlkjr's Avatar
wlkjr wlkjr is offline
My water pump made a slight squeal and replacing it fixed it. I have also heard bad bearings in an alternator make a squeal.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 09-10-2008, 12:26 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
I have run into that squeal in the past. Another shop had installed a new upper plenum and did not install the PCV valve. The noise in this case was actually air rushing into the engine through the rear valve cover gasket. I'll admit I scratched my head for a few minutes before I put all the pieces together on that one!!
Old 09-19-2008, 02:09 PM
Just an update, so far so good, no more noise since I installed the new PVC kit from the dealer. Keeping fingers crossed. I will no more tonight since I will travel about 100 miles. Everything else since then has been local driving. Thanks for all the suggestions.
Old 09-19-2008, 08:11 PM
Just got back from my 130 mile road trip and all went well, no noise. Thanks again for all the help.
Old 09-20-2008, 07:20 AM
richtazz's Avatar
You are very welcome. Thanks for the feedback as we like happy endings, and it may help someone else reading this thread with the same issue.
