Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 08-03-2008, 12:46 PM
lllance lllance is offline
aftermarket cd player problems
My car has a infinity sound system, and when I install a aftermarket cd player, it only plays the radio and not cd's
Old 08-04-2008, 12:25 AM
AWP9521 AWP9521 is offline
Re: aftermarket cd player problems
Chrysler uses the Power Antenna lead to raise the antenna (if the car is so equipped) and also turn on the Infinity Amp in the trunk when the radio is switched on.
Some of the newer aftermarket head units have two remote wires, one wire is for a Power Antenna (Normally a blue or blue/white wire), and the other is for an Amplifier Remote Wire (unsure of color but check your installation manual for the correct colors of both of those leads).
The Power Antenna wire is only active if the Head Unit's Radio is in operation, but when you switch the Head Unit source to CD, it cuts power to that lead (Lowers the antenna) since the radio is not needed.
The Amplifier switch lead is live all the time the Head Unit is in operation and drops only when the Head Unit is turned off.
In your case you followed the instructions and connected Power Antenna wire where the harness connection instructions said to, no foul there, you simply need to remove the Head Unit's Power Antenna lead from the Harness Connector and tape it off and then connect the Head Unit's Amplifier Remote wire in it's place and your good to go.
Caution: never connect both the Power Antenna and Amplifier Remote wires to a single Harness Connector connection, you can damage the Head Unit.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
