Old 03-11-2003, 03:30 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Question Completed H22 Swap: Shiftlinkage/Syncros Problem...
hello i got the swap done in my 95 4dr civic; and i am having trouble with my shiftlinkage (i'm hoping)...it's not allowing me to downshift into 2nd and sometimes when i do the 1st to 2nd shift it grinds and sometimes it doesnt i'm hoping its not the syncros. i used an 91 accord shiftlinkage and i ran it under the steering rack its kind of tight; there isnt alot of play in the linkage. just want to know your thoughts or if you have heard anything about this?
HCP said to double clutch when down shifting, but there has to be a better way to fix the problem. Also heard something about possibly needing a short shifter to shift properly can any one back this up (and if so what short shifter will work)? Any help is GREATLY appreciated.
Old 03-11-2003, 06:51 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you have to double clutch, then its probably a syncro. unless the shift linkage is touching something
Team Lonely Drivers
Old 03-13-2003, 02:31 PM
CivicSpoon's Avatar
There is no Spoon
Thank you for your answer, I'll check it out and see if it's hitting anything; as soon as my friend gets it back from being painted. Thanks Again.
Old 08-03-2003, 01:42 PM
SLEEPERACCORD SLEEPERACCORD is offline
AM HAVING THE SAME PROBLEM.BUT I USED THE ACCORD TRANNY AT FIRST FOR THE LONG GEAR RATIO AND IT WAS VERY HARD TO GO INTO GEAR.THEN THE TRANNY WENT UP ALL TOGETHER.THEN I WENT TO THE H23 TRANNY SAME THING!.NOW AM WITH THE H22 TRANNY AND IT STILL DOING THE SAME THING THE SHIFT LINKAGE IS NOT BINDING UP.SO WE STILL WORKING ON THAT BUT IT ONLY DOES IT WHEN EVER I TAKE THE RPM TOO 8K I ALWAYS HAVE TO LET THE RPM DROP TO AROUND 5K TAP THE GAS THEN SHIFT.
01" ACCORD PERFORMANCE MODS:
JDM H22A MOTOR SWAP
EIBACH PROLINE SPRINGS
DC SPORT SHORT THROW SHIFTER
GReddy EVO CATBACK EXHAUST
O15 18"WHEELS NITTO 450
REV HARD T3/T4 TURBO WITH .54 TRIM
PWR 31X11X3 INTERCOOLER
ADJUSTABLE FMU 12:1-14:1 RATIO
550cc INJECTORS
VAFC
MANUAL BOOST CONTROLLER
GReddy TURBO TIMMER
AEM CAM GEARS
AEM UNDERDRIVE PULLYES
ACT EXTREAM CLUTCH/PRESSURE PLATE
ADDED 1 EXTRA FUEL PUMP(INLINE)
BOOST GAUGE
EGT GAUGE
AIR/FUEL RATIO GAUGE
TURBO-XS RFL BLOW OFF VALVE
BFG DRAG RADIALS 225/50/15(2)
FUTURE PLANS:
FULL BOTTOM/TOP END BUILD UP
AM 8PSI NOW.
