Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-02-2008, 08:09 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
light comes on while taking turns
Hey guys,
so I noticed lately that I have this mysterious light come on sometimes when i'm taking turns at high speeds (at least thats when I have noticed it most).
i'm not sure what light it is cause it only flashes for an instant but its located on the bottom right of my instrument panel.
so if anyone could let me know what is possibly going on my car that would be great thanks
Old 08-02-2008, 10:16 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: light comes on while taking turns
What color is it? I'll bet its the low coolant light. The low coolant level light is amber by the way.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-02-2008, 11:00 PM
yeah, it is kind of amber. Why would it come on during turns.
I guess I will check my coolant levels out
thanks
Old 08-02-2008, 11:46 PM
ned032002's Avatar
ned032002 ned032002 is offline
Chances are that when your turning, the fluid is sloshing around and causing the sensor to read that there is not fluid. Check it and top it off.
Old 08-06-2008, 03:16 PM
it still seems to be coming on, are you guys sure its the low coolant light, could it be something else?
I wish it would stay on for more then a quarter of a second
Old 08-06-2008, 04:07 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Is it red? The oil pressure light may come on if it's low. Mine done that a couple times back when I was leaking oil badly and I wouldn't check it. If I hit a turn hard, it'd flash on just for a split second and then cut out.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Thor06's Avatar
Jizzed In My Pants
It has happened to me, even in the reverse. When I over heated and lost some of my coolant out the dump tube at the North Meet, my low coolant light was on and I had to speed up real fast to get around a semi, then lock them up so I didnt hit Dave which turned my coolant light off for a while. Do you happen to be catching what color it is?
Old 08-06-2008, 04:16 PM
orangeish, its the far bottom right light
Old 08-07-2008, 12:12 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Does it look like a radiator/Roman temple/fence gate/insert random thing people have come up with on Tuners?
If so, coolant.
Kris
2012 Genesis Coupe 2.0t
Old 08-07-2008, 01:08 PM
david-b's Avatar
Dave is THAT guy
Thanks. Makes me feel good that I still have the rear-end to my car.
My coolant light has NEVER come on in my car. Even with 4 different coolant tanks and sensors, it has never come on. Don't really care, but just always kinda wondered why not.
75 Monte Carlo
