Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 08-02-2008, 04:37 PM
tallman777 tallman777 is offline
Trying To Flush Fuel Injectors
I am trying to flush the fuel injectors thru the schrade valve on a 94 Ford 4.9 engine, and have plugged the return line, it seems that the cleaner is backing up and returning to the fuel tank ,I do have the fuel pump disconnected ! I have not been able to locate a plug or adapter to cap the fued line off .any advice will be greatly appreciated . Thanks
Old 08-05-2008, 06:11 PM
rhandwor rhandwor is offline
Re: Trying To Flush Fuel Injectors
Pull the fuel pump fuse or relay. On the back of the engine find the return line pinch off the rubber hose. I imagine your using a canister that you put air pressure in to install the injector cleaner. You can also pinch the hose for the pressure side. Pull the vacuum hose for the pressure regulator if leaking gas replace.
Old 08-10-2008, 04:45 PM
the line coming from the fuel tank at the engine is wrapped in stainless steel and it is stiff is it safe to clamp this line? Thanks
Old 08-10-2008, 07:21 PM
If I'm remembering correctly their are rubber lines at the fuel filter I would pinch one of these off.
