Go Back   Automotive Forums Car Chat > Buick > Century
Old 08-02-2008, 04:22 PM
androcks androcks is offline
1999 Century Power Window Problem
Hi everyone. I rolled up all the windows in my 1999 century and went into a restaurant for lunch. When I returned to my car the front driver's side window was rolled down about 2 inches. I tried to use the control to put the window up, but it did not work. I then put the window all the way down hoping that it would go back up. It did not.
Now I am left with a front driver's side window that is stuck in the down position and will not go up. All the other windows work perfectly. When I engage the button to try and put the broken window up I can hear the sound of the motor spinning inside the door, but nothing happens.
Anyone know what I need to do to fix this problem? Thanks in advance!
Old 09-03-2008, 02:08 PM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Question Re: 1999 Century Power Window Problem
Sounds like the regulator has passed on . The window goes up and down with a cable and pulley type of setup . If you can hear the motor running but the window doesn't go up or down , this pulley system has failed . I don't think parts are available seperately to fix this . You'll have to replace the entire unit and most also come with a new motor . Save the old motor for future needs .The regulator from the dealer will be in the $400 range. You can probably find one on Ebay for a much lower price . Good luck and let us know the outcome !
Old 09-03-2008, 02:40 PM
Thanks Blu!
The regulator was indeed the problem. Somehow the cables had jumped the tracks they were supposed to be in and had frayed badly.
I was able to find a regulator separate from the motor. It only cost me about $40 after shipping. After putting the new regulator in everything works great!
Thanks again for the help.
Anyone having similar problems should refer to this page:
http://free-auto-repair-advice.blogs...regulator.html
It has a step by step walkthrough and pictures that make replacing the regulator yourself fairly easily.
Old 10-21-2008, 11:57 PM
papason papason is offline
Hi, I am habving trouble with my driver window not going up. I have always hated taking off door panels, things always break and getting them back on nice is ..... I dont want to start pulling until I know how it is attatched or how to take it off.
Any help? thank you
Old 09-18-2009, 08:51 PM
Satellite Satellite is offline
go to the local bone yard for the part and maybe if you got a you wrench yard nearby you could pay as little a 20 sugar smacks
