Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 08-02-2008, 04:01 PM
ericwarren ericwarren is offline
Signal Flasher needs replaced
I have a 95 pontiac transport, and need to replace the signal flasher. Left side works fine, right side not so much. I already bought and replaced any bulbs that needed it and bought a new flasher, I just can't seem to locate the flasher in the van?
Old 08-06-2008, 11:04 PM
96tsport 96tsport is offline
Re: Signal Flasher needs replaced
Should be able to hear the flasher unit clicking & follow the noise.
~70k last 3 years with no major issues ~270k total; unknown prior history.
Old 08-07-2008, 11:16 PM
Jeffrv's Avatar
Jeffrv Jeffrv is offline
Flasher unit is loctaed under the instrument panel to the left of the steering column. manual says to remove the lower sound insulating panel and then it is quite accesible. You can get at it without removing the panel, but, from experience, be prepared to leave a lot of skin on sharp metal edges The same flasher is used for both left and right signals, so if it works ok on the left side I don't think the flasher is the problem. If it blinks rapidly on the right side I would suspect a short on the front or rear harness, of if it doesn't blink, and open there. Also there may be a problem with the signal switch itself
Good luck
Jeff
Old 10-12-2008, 06:10 PM
Deltadogblue Deltadogblue is offline
I Have a 1998 pontiac transport montana van and I have a turn signal problem too.When I start the van the turn signal lights work perfectly O.K. but after 2 minutes the lights stop working and flasher relay stops ticking. Is it the flasher relay problem or any thing else . where is the flasher relay fitted how does it look like Thanks
Old 12-15-2008, 01:58 PM
elroyas's Avatar
elroyas elroyas is offline
This looks like a bad flasher relay. The o.e. works with a bi-metal contact breaker.
Just buy a better one with a proper relay inside it.
I don't know where it is located in the Montana but it has the shape and size of a C-cell battery, with a 2 or 3 wired connector at the bottom. Easy fix!
Old 12-25-2008, 05:17 PM
SgtFang SgtFang is offline
Does the panel just pop right off? My Haynes manual shows it already removed, but I didn't want to just jump in and start prying until I knew for sure.
Thanks!
-Sarge
Old 12-25-2008, 06:49 PM
On my 96, the lower panel came off with a few screws & maybe one (or a few) had a bolt head.
