Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-02-2008, 03:05 PM
mgntwo mgntwo is offline
starts, dies, then wont start
Hey guys i have a 95 towncar that just devolped a new wierd problem. I went to start my car the other day, it started and died withing 10 seconds, then when i went to restart it all it would do is crank but not turnover. couple days later i tried to start, it started and gave it a hell of alot of gas and stayed running and ran fine but again check engine light for excess egr flow came on. couple days i tried to start her and sdame thing started for 10 seconds, died then would just crank crank and crank. Any idea of what causing this situation. Obviously im think a fuel problem possibly injectors or any other route???
Old 08-02-2008, 05:01 PM
danielsatur danielsatur is offline
Re: starts, dies, then wont start
A bad EGR valve,or bad gasket is like a open window to the Intake,it's
like a bad vacuum leak.
You might want to put a turnicate or block EGR port to Troubleshoot the
problem.
I would get some gasket material and make a EGR gasket without the port hole.
Take the EGR bolts out and force EGR 1/8'' away from the exhaust manifold.
Sneak new gasket in between and bolt down tight.
This will isolate EGR,GASKET,Feedback sensor,and electric solenoid from the Engine.
How does the car run?
MCGIVER
Old 08-02-2008, 08:59 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Hello, try this.. Sounds like your fuel pump is going bad.. climb under the car and hit the bottom of the gas tank near the front of it. if its safly possible try and have someone to start the car as you are hitting the tank. If it starts up then I would vouge to say your fule pump has a flat spot on the bushing and needs replacing. Or you can take it to a shop and have them do a pressure check and see how many pound of pressure its putting out. I doubt its a vaccum leak unless you hear it sucking air around the engine. To check for a vaccume leak, spray intake or throttle body cleaner around the engine while/if you can get it running, if there is a leak you will notice the engine will run more smoothly. Also, if you would like, spray the carb cleaner into the intake box and have someone try starting the engine. If it stays running while your spraying and dies when you stop thats another way of checking/knowing that the fuel pump is bad...
good luck
Bryan
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 08-06-2008, 02:15 PM
is there a port on the fuel rail i can check to if it has pressure instead of getting underneath it
Old 11-20-2008, 10:23 PM
iambliss04 iambliss04 is offline
idle air control valve
