Old 08-02-2008, 11:01 AM
Bubbagnh5 Bubbagnh5 is offline
Engine tick
My 1997 cavalier 2.4L has a rapid tick/knock when idleing but when I rev up the engine it seems to go away. What could be the issue is a rod consistant where valves are inconsistant?
Thanks
Mike
P.S. I may try to get a video this weekend and try to paste link here.
Old 08-02-2008, 05:56 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Engine tick
It's impossible to know without hearing it. You can use a screwdriver as a stethoscope to pinpoint where the noise is coming from.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
