Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-02-2008, 08:32 AM
polby111 polby111 is offline
95 talon smokes rings or valves how to tell
smokes a lot in low rpms but tries to clear up in higher rpms
Old 08-05-2008, 02:18 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 95 talon smokes rings or valves how to tell
Is this car turbo?
Smoking due to valves usually is worst at startup (oil has had time to run down the valve stems over night for example) then clears up. Sometimes still smokes lightly on decel.
Smoking due to rings can happen all the time. Compression is probably low.
Smoking due to turbo can happen all the time. This is fairly easy to check, just pull the intake and the DP and look for excessive oil.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 08-05-2008, 04:52 PM
thanks helped alot
not turbo
Old 08-05-2008, 06:18 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
What color smoke? White means water, blue means oil, black means running rich.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 08-05-2008, 07:28 PM
AF - Advisor
I've seen the color thing fail occassionally. Some times it's just too hard to tell. For example, I've seen ridiculously white oil smoke, as well as very black oil smoke. I think it all depends on how much oil is being burned perhaps. But water is always white, and rich is always black, so that much is trustworthy at least.
Kevin Jewer
