Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-02-2008, 04:44 AM
Roel1987 Roel1987 is offline
Exclamation 1997 MGM New coil springs in front and still sags
Need some help!!! Please... I have a 1997 Grand Marquis LS with 102K and rear air suspension on it. I replaced the front coil spring due to sag problems, new coils, new shocks, new swaybar links, and still seems to sag a little. I measured the height from the fender wells to the floor and the front measurments arent as bad as the rear measurements. The rear seems to sag more to the passenger's side, than the front. I took a look under the car, at the rear suspension and found cracks on the (passengers side) air bag only. Doesnt seem to leak or loose air. Could this cause the rear to sag and making the front to look sagged???? This sag look is anoying!!!
Old 08-10-2008, 08:41 PM
rhandwor rhandwor is offline
Re: 1997 MGM New coil springs in front and still sags
I would think one side would be higher and the other would be lower.
http://www.suncoreindustries.com/ Sells spring conversion and new inserts for the rear if needed.
Monroe makes a shock with a spring around it which will help somewhat.
