Go Back   Automotive Forums Car Chat > Ford > Aspire
Old 08-02-2008, 12:56 AM
shinta shinta is offline
need help with a 1990 Ranger
let me start off by saying sorry for the grammar and spelling
ok a friend has a 1990 Ranger. he first problem was she let ppl mess with it that did not know what they where doing. they replaced the clutch, presser plate, throw out barren, and slave ciylder. when it was all said and done the frist week it was fine. then you had to put it in 1st or R to get it to move. it wont shift into gear for a dead stop or down shift eather.
its like when you try to shift form last gear to R realy fast or for R to a gear it dont work it stops. well thats what it is doing. i have even tryed to get it to grind it wont even do that at a dead stop.
any help would be great. we are trying to keep it out of the shop if we can.
Old 08-02-2008, 03:16 AM
Davescort97 Davescort97 is offline
Escort guy
Re: need help with a 1990 Ranger
Welcome to AF. Sounds like the slave cylinder needs to be bled.
Old 08-02-2008, 09:54 AM
well we have did that and it still doing it
Old 08-02-2008, 12:22 PM
rhandwor rhandwor is offline
These slave cylinders are very hard to bleed. I would try again.
Old 08-02-2008, 01:23 PM
ok do what about a bottle fluid?
Old 08-02-2008, 06:37 PM
I always replaced both the clutch master and slave cylinder. The bleed screw is close to the transmission. You put the fluid into the clutch master brake fluid. You have to move the clutch pedal up and down to bleed. One mechanic told me two hundred times. If I misunderstand what you want ask again.
Any way they are hard to bleed.
Old 01-30-2015, 12:03 PM
Gene K. Goebel Gene K. Goebel is offline
I have a 1990 Ford ranger 4x4/ 2 liter. i got the hubs locked in but when i push the 4x4 button or the 4x4 low button it doesn't do anthing. no noise. nothing. and the 4x4 will not engage. any ideas at all the could be wrong that needs fixed
Used Spare Parts
