Old 08-01-2008, 04:59 PM
GoBears's Avatar
GoBears GoBears is offline
Code P0300 - Random misfire
Hello everyone. When I got my 00 GTP it had the SES light lit and would stumble under acceleration. It would also occasionally stall. The SES light was the MAF voltage. I got a used MAF sensor from the local junkyard. The idle and stalling are completely fixed now. The car still stumbles though when pushed. The code it throws now is P0300-Random misfire. I figure a good tune up is the next step and am looking for opinions on what type of plugs and wires. Money is very tight right now (got a baby boy coming!) so keep that in mind.
Thanks all
GoBears
2000 Pontiac Grand Prix GTP
Old 08-01-2008, 07:15 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Code P0300 - Random misfire
The first place to start are plugs and wires. A bad plug or a bad wire can cause the random misfires. If you had a misfire on one or two cylinders the issue could be a coil but at this point start with the above. If that doesn't eliminate the problem then you may need new coils or a new ignition module. That is where you can go through some money very rapidly so I hope the plugs and wires fix the problem. You may also want to change the PCV valve too. Only costs a couple of dollars and don't forget the fuel filter. Fuel starvation can cause the same issues. Good Luck and let us know how it works out.
Old 08-02-2008, 12:26 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
I'd rent a fuel pressure guage and check fuel pressure first.
Stick with ac delco plugs and wires. for all 6 plugs and the delco wire set, the total shouldnt be any more than 100 bucks.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-02-2008, 03:43 PM
CrazyHorst CrazyHorst is offline
Respectfully, have you ever seen a bad PCV valve? I never have.
If the OEM spark plug wire "organizers" are pillaged or not used, it is fairly easy for a wire to start to chafe a little and then develop a "short" which can arc energy to ground. I put that "short" in quotes because it's kind of an "electrical leak" which doesn't force the energy to jump the gap to ground....instead it takes a path of lesser resistance.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 08-02-2008, 09:39 PM
tblake's Avatar
In God We Trust
I think plugs and wires are probably a good place to start, but if a wire were bad, woundn't he see a PO302 for a single cylinder instead of a PO300? Which is why I tend to lean more towards fuel or air delivery problems.
