Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-01-2008, 02:59 PM
floresmaxima floresmaxima is offline
CV Boot
I have a 96 Maxima and just recently notice that the outer cv boot in the driver side is rip and also notice grease on top of the caliper. How hard is it to replace it I have the knew cv boot including the grease and clamps. Any suggestion on how to replace it
Thank You
Old 08-01-2008, 04:13 PM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
Re: CV Boot
Thank You
Not too tough, but it also depends on how long you have been operating with the tear. If water or contaminants have gotten into the CV joint, you will want to replace/repair that as well. It isn't worth going through the whole procedure of putting a boot on if you have to do it again in a month because the joing is bad. How much mechanical experiance do you have?
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
Old 08-01-2008, 06:51 PM
Re: CV Boot
O.K I do have some knowledge not much but enough to do the work and been driving the car for a week now since I noticed the problem. Its there any special tool I may need to do the work.
Old 08-02-2008, 03:17 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: CV Boot
...any special tool I may need to do the work.
"100 miles" is enough to get sand in and grinding to start ... will grind the joint surface during next few kmiles. (Grease on caliper means more than "100 miles".) Then the joint starts to go and will be heard = Patching over with new boots is useless when the sand is already in.
As u dont (?) know how long boots have been ripped, replace the joint...
On the market there are quite a few axles that are sold for maxima. Problem is, some 'fit' in but start dropping off from bores later or whatever complications. U need a mech pro to make sure the replacements are exactly equal.
Check out this writeup http://www.cardomain.com/ride/748507/25
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Old 08-02-2008, 12:31 PM
RaeRae1's Avatar
Re: CV Boot
^^ I would go with this suggestion. Since I am not up on the Maxima I cannot tell you for sure. With my Sentra I simply replaced the entire half shaft. It is relatively inexpensive and much easier to accomplish than tearing apart the joint.
Good luck. Let us know how it turns out.
Old 08-03-2008, 05:20 PM
Re: CV Boot
Well guys thank you for all the input. I did the work today replaced the cv boot and let me tell you that it wasn't that bad. It took me about an hour to pull out the shaft, look at the joint and seem o.k no need for replacement which is good put everything back together but it took me about 2 1/2 hour to finish the work took it for a drive test and its o.k. Once again thank you for the input.
Old 08-04-2008, 02:19 AM
Re: CV Boot
... look at the joint and seem o.k no need ....
Been t here, "seen" t hat -and- hoping [on the worn joints]...
Its good exercise to add new grease and renew a boot, this possibly adds few more kmiles - before the joint cracking sound arrives.
