Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 08-01-2008, 11:35 AM
luxeryvic luxeryvic is offline
1977 monte shifter cable?
ok, i will try to explain this the best i can . . . here it goes
the car is column shift everything shifts good but when it shifts the selector/indicator on the dash that tells you what gear u are in doesnot move
ive heard that it is an easy fix and the cable/linkage is just broken, where can i find one of these cables, would NAPA have it and how do i take out the old cable and put the new one in?
thanks, hope everyone understands this
Old 08-01-2008, 11:49 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 1977 monte shifter cable?
The part that you're talking about is referred to as a shift quadrant. It's basically a pointer with a little steel cable that attaches to the outside of the steering column - the part that moves with the trans shift lever.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-01-2008, 04:25 PM
so how do i get the old one out and where can i get a new one?
Old 08-01-2008, 07:36 PM
silicon212's Avatar
Confoundingly Lucid
Like I've suggested to you before, you need to get a manual for your car. A manual, such as a Haynes or Chilton's manual, will detail how the procedure is performed on your specific car.
Old 08-04-2008, 07:52 AM
i have a haynes manual and i cant find anything in it, whenever i have a problem i always lookin in the manual first ( far easier and faster ) then sometimes i post here.
Old 08-04-2008, 11:32 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I had a Haynes manual and it was so bad I tossed it. I picked up some factory GM manuals on eBay that were tons better than the Haynes. Chiltons is better than nothing.
Try your local library. They may have manuals in the reference section. You can't take them out, but you can copy anything that you need.
Bob
