Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 08-01-2008, 12:53 AM
isis101us isis101us is offline
How do You turn it off?
How do you turn off the check air suspension light? I've had regular springs put on and now I just need to get the warning light to not come on. Is there a way to turn it off?? It's a digital dashboard.
Old 08-01-2008, 07:00 AM
rhandwor rhandwor is offline
Re: How do You turn it off?
When all else fails remove the bulb. Anyway look in the wiring diagram and check for a fuse for this item. Hunt the sensor and pull the power for it.
Old 08-01-2008, 01:42 PM
Cgroh89 Cgroh89 is offline
Can you have it tuned out of the computer?
Old 08-07-2008, 11:33 PM
Cool Re: How do You turn it off?
Well unpluging would be impossible due to it's digital dashboard.... I'll have to find a way to "trick" the computer into thinking it's working. I'm told that because it's digital, there's nothing I can do about it coming on.
I'm worried that the smog station will have a problem with it and refuse to pass my car (next year when it's due for a smog) even though it runs like a dream.
Old 08-08-2008, 05:43 AM
Check for a fuse for this system surely their is one. The digital dashs I worked on had a big plug on the back with wires to feed it they are numbered and color coded. They also had bulbs for the trouble lights so you didn't need to buy a complete instrument panel. Pull the instrument panel and put in burned out bulb. You can also cover with black tape. Use a magic marker and mark where the bulb is located. This way you don't need to get into the wiring. Your not working on the digital part of it just the indicator light.
This cheaper than failing an inspection.
http://www.alldata.com/ sell a years subscription for $29.95 they recently gave me a quote for five years at the same cost. Cheaper for other vehicles. I would recommend guidelines when pulling the dash.
Old 08-08-2008, 07:44 AM
reekor reekor is offline
Unplug the air ride module behind the glove box. its mounted on the heater box.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
