Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 07-31-2008, 06:37 PM
dan89 dan89 is offline
Can anyone identify these wheels?
Just traded my ICW 17's for these 15's... anyone know what brand they are? 4 lug dual pattern...
Have this odd logo on em
Thanks guys
click for my cardomain ^
Old 07-31-2008, 07:47 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: Can anyone identify these wheels?
The JWL logo is on pretty much all wheels.. I'm pretty sure it's an authentication logo, something to do with U.S. inspection and road legality.
Could be wrong tho, It's happened before.
Old 07-31-2008, 07:52 PM
oh ok thanks
it also says VIA 690kg and 15x6.5 JJ if that helps anyone
Old 07-31-2008, 07:58 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Nope, that just tells you the weight for something, not sure, and what size the wheels are, diameter and width.
I honestly don't have a clue what wheels they are, ofcourse I don't keep up with wheels anymore unless they are stock or some of the common ones everyone uses.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 07-31-2008, 08:07 PM
google VIA, and ignore anything having to do with computers or chips..
(VIA is a through hole in a circuit board... )
Old 07-31-2008, 08:18 PM
tryed that but came out with like 6000 hits... I'm just curious really
maybe when i get the tires replaced i'll have a look at the wheel and see if there's any sticker left
Old 07-31-2008, 10:15 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yeah the first number is the load rating, followed by size.. dunno what the jj is though.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-31-2008, 11:59 PM
Tony's Avatar
TLD Member #1
I know its on a lot of wheels, just don't know the real meaning behind it. It always follows the dimensions.
Tony
Old 08-01-2008, 05:40 AM
CapriRacer CapriRacer is offline
Originally Posted by FrodoGT
..... dunno what the jj is though.
The JJ is the rim flange contour. Flanges come in different configurations, but as a general rule you don't have to worry about it when dealing with passenger car tires. They are pretty much all JJ.
Old 08-01-2008, 03:55 PM
Hey... I didn't have to explain that one... good thing too, I didn't really wanna dig out my sears books.
BTW, some are also just "J" for whatever reason, but IIRC, they're the same flange dimension.
Old 08-02-2008, 05:47 AM
Ah .... Mmmm ...... Not exactly.
J and JJ are slightly different, but for practical purposes, they can be used interchangeably.
Old 08-02-2008, 05:58 PM
isn't that the "lip" designation, telling you what type of weight to use? or soemthing like that... still haven't gotten those books out, don't really care enough, I don't use weights on my rims normally, I zero balance them.
Old 08-03-2008, 06:41 AM
isn't that the "lip" designation ........
Yes, it does tell you about the "Lip". The technical term is "Flange". The JJ defines the shape of the flange, but only where the tire and the rim interact.
No, it does not tell you about the type of weight needed. The area where the weight is hung is outside the area defined by the "JJ".
Ah ..... Mmmmmm ....... - how do you "Zero Balance" them without weights?
Old 08-03-2008, 09:22 AM
Have you ever noticed that there is usually a marking (dot) on new tires?
Put that marking near the valve stem, and spin the tire
Mark where the weight should go
Break the tire back down, flip it so that the OEM mark is 180 from the valve stem, spin it again
Mark the new spot for the weight
Your "sweet spot" is somewhere between those two markings.
If you break the tire down, turn it so the valve stem is between those two markings, you'll (eventually) find a "zero" balance.
Yes, it's alot of work, but I REALLY don't like weights... so I go to sears to get my tires mounted, and they let me do it... (I used to work there)
I can actually get the info from them, that has pics and shit of what to do, the next time I buy tires... they'll give me the book that explains how to deal with mismatched tires and tires with more than one OEM dot and shit like that...
Yes, it's a lost art... b/c it's a slow process.
Old 08-03-2008, 12:26 PM
US Wheel US Wheel is offline
looks like a enkei or konig wheel. the center caps usually have a logo at the center. If the logo is similar to a figure 8 then its a enkei. If the logo looks similar to a crown then its a konig. The 690kg is a part# to a wheel
www.uswheelremanufacturing.com
