Old 07-31-2008, 05:54 PM
JohnCHawk JohnCHawk is offline
Kenwood KAC-7202 Fuse problems
I have a kenwood KAC-7202 Stereo power amplifier, its hooked up to two 12inch subs and it goes to a Alpine Deck. Once I get up to about 20-25 volume the fuse burns out. Its a size 30 of the standard plastic fuses. Why does it continue to burn out the fuse? How do I fix this?
Don't know much of anything about the technical part of installations and things like that. Just let me know what I need to stop the fuse from popping/burning out.
Thanks - JC
Old 07-31-2008, 06:42 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Kenwood KAC-7202 Fuse problems
you most likely are playing the amp past it's max volume and it's just protecting itself. How much power does this amp produce and what size (gauge) power and ground wires do you have ?
Old 08-01-2008, 04:06 PM
I just downloaded the OM of the amp and here is the specs
Audio Section ......... KAC-7202
Max Power Output ..... 920 W
Rated Power Output (+B = 14.4 V)
Normal (4 Ω) (20 Hz – 20 kHz, 0.08 % THD) .... 150 W × 2
Normal (4 Ω) (DIN : 45324 , +B = 14.4V)..... 150 W × 2
Normal (2 Ω) (1 kHz, 0.8 % THD) ..... 230 W × 2
Bridged (4 Ω) (1 kHz, 0.8 % THD) ........ 460 W × 1
Sensitivity (rated output) (MAX.)........... 0.2 V
Sensitivity (rated output) (MIN.).......... 5.0 V
Input Impedance ..........10 kΩ
Frequency Response (+0, –3 dB) ...... 5 Hz – 50 kHz
Signal to Noise Ratio....... ≤100 dB
Low Pass Filter Frequency (24 dB/oct.) ..... 50 – 200 Hz (variable)
High Pass Filter Frequency (12 dB/oct.) ..... 50 – 200 Hz (variable)
Bass Boost Circuit ........ 0 – +18 dB (variable)
Bass Boost Frequency ...... 40 Hz
General .......... KAC-7202
Operating Voltage ... 14.4 V (11 – 16 V allowable)
Current Consumption ......... 40 A
Not sure how to measure current power output, guessing just a regular voltometer. I also read in this manual i got today that the size fuse should be 40 AX1 so instead of the 30 I am going to try that see how much better this thing can go. I didnt do the wiring myself so not positive on that but i can find out. I believe they used the rockford RFK4, the only thing diffrent is that instead of the 60amp i have a 100amp at the battery.
Old 08-01-2008, 05:06 PM
Just tried the 40 amp fuse and it gets higher volume (around 26-10) then still burns out, also noticing that the bass kicks on and off at times, maybe a loose connection?
Old 08-01-2008, 06:09 PM
Audio Guy
check your ground and power connections, make sure they are tight
