Old 07-31-2008, 04:14 PM
wrenchtwister1 wrenchtwister1 is offline
Question 92 LeSabre electric window problem
I have a problem with my windows (all of them) when I let them down, they won't come back up unless I remove door panels and reverse wire. What could I do to remedy this??
Old 08-08-2008, 07:45 PM
3echo9 3echo9 is offline
Re: 92 LeSabre electric window problem
I had the same problem and was able to fix the problem by spraying electronics parts cleaner to the window switches.
Make sure you disconnect the battery then disconnect the electrical connectors to your window switch in the door. Spray liberally and let dry. If that doesn't work try to find a replacement in a salvage yard.
Good luck.
2005 Chevy Equinox LT 186,000 mi
2004 Buick LeSabre 200,860 mi
2011 Infinity G37x 103,000 mi
Old 08-10-2008, 06:08 AM
Thumbs up Re: 92 LeSabre electric window problem
Thanks, that solved my problem.
