Old 07-31-2008, 09:49 AM
chuck0 chuck0 is offline
Question No start event/Theft Deterrent Re-Learn procedure
I've had a "no start" occurring about 4X a year until recently. Now the "no start" is occurring everytime I try to start the car. I'm always able to start the car after using the "Theft Deterrent Re-Learn" procedure except that it always starts after the first 10 minute sequence. This procedure was last listed by LittleHoov in "Another Starting Problem (last post 7/03/08).
I have (2) questions:
1. Am I doomed to use the "Theft Deterrent Re-Learn" procedure forever?
2. The "Theft Deterrent Re-Learn" procedure always restarts the car (after the first sequence) when I go to step 5. of the procedure.
Is there any importance attached to the fact that I cannot repeat this sequence for the 2nd and 3rd time because the car started after the 1st time?
Old 07-31-2008, 10:19 AM
dtownfb dtownfb is offline
Re: No start event/Theft Deterrent Re-Learn procedure
By "no-start" do you mean your car will crank and crank but not turn over?
Based on what you are describing, it appears the problem is with the ignition switch. Very common problem.
The other question is are there any "Check engine" lights on?
Old 07-31-2008, 11:17 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Does almost sound like the ignition switch might be screwing up to the point it needs outright replaced, but I cant say with any sort of authority whether thats true or not.
Just know that Im thinking of replacing mine soon, because every so often, always at inopportune times, I get a no-crank with a flashing Security light. But if I let it sit for about 10 minutes, then come back out it will start right up.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 07-31-2008, 12:13 PM
Sorry that I was not clear. By "no start" I meant "no crank" also. There is complete silence except for an "oh shyt" that comes from me. The instrument icons are lit up along with a flashing security light.
My question #2 was that I can never get to step #8 of the T.D. Re-learn procedure without the engine starting. The engine starting is a good thing but,does the system re-learn if this procedure isn't completed through step #8?
Old 08-01-2008, 03:15 PM
aghopkins aghopkins is offline
I had the same problem on my car about two years ago. First it was very intermittent but eventually it started happening every day. I would have to let it do the relearn procedure 2-3 times before it would even start. I had the dealership replace the PassLock module on the ignition switch. So far I have not had the issue resurface although I do occasionally see the Security light come on while I am driving. It was done under warranty so I am not sure how much it costs. Hope this information is helpful.
Old 08-02-2008, 09:29 AM
The ignition switch itself will cost $90-$120 depending on what brand and where you get it. LittleHoov has posted the instruction on removing and repplacing the ignition switch.
