Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 07-30-2008, 10:56 PM
racingsaturn55 racingsaturn55 is offline
Send a message via Yahoo to racingsaturn55
92 saturn sc hesitating and running rich
my 92 saturn sc dohc hesitates when i accelerate and it is running rich. ive already cleaned out the throttle body and map sensor and got a new 02 sensor but it hasnt helped yet. what do you think the reason its doing thins for?
Old 07-30-2008, 11:19 PM
Cat Fuzz Cat Fuzz is offline
Re: 92 saturn sc hesitating and running rich
Change your coolant temp sensor. The two wire sensor below the EGR valve. 13mm deep well socket is all you need. You'll spill a bit of coolant, depends on how fast you are getting the new one in.
Old 08-02-2008, 01:52 AM
Ok, lets try to keep the discussion here instead of PM's so that it might help future board users. You asked:
Originally Posted by racingsaturn55
"How does the coolant temp sensor affect it like that. I wouldn't of guessed it would do anything."
The coolant temp sensor is absolutely critical to the PCM for proper engine management. If the PCM can't tell how hot or cool the engine is, it can't properly manage the fuel system. It is easily one of the most important sensors in the system.
When the car starts cold, the PCM adjusts the fuel mixture to a 'rich' state to keep the cold engine running smoothly. On older carburated engines this was the chokes job. As the engine warms up, the PCM can lean out the mixture because the warm engine needs less fuel to stay running properly. If the coolant temp sensor goes bad, the PCM will constantly run the engine rich just to be safe since it can't tell if the engine is hot or cold.
Old 08-02-2008, 10:27 AM
RC1488 RC1488 is offline
my 92 saturn SC2 dohc
CF is totally on about the sensor. Supporting how important the sensor is the PCM also uses it for some of the following sub systems: Idle rpms, air/fuel, timing, emissions control, tranny operations (automatic), and fan control.
One more thing. Replace the ECTS with the 2-wire sensor.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 08-04-2008, 12:59 PM
Thanks for helping me out with this problem. I just put it in today and it ran perfectly. Their was no hesitation at all.
Old 08-04-2008, 11:37 PM
Cool.
