Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-30-2008, 08:12 PM
kmanracing24's Avatar
kmanracing24 kmanracing24 is offline
Rear End Questions
I have a 1985 caprice classic with a 305 (vin H). I was looking at getting a posi for my car. The problem is that i have no idea what the specs are for the rear end for my car is. Does anyone know the axle model, number of cover bolts and axle shaft spline count?
1985 Chevy Caprice Classic 5.0L
1995 Honda CBR600F3
2000 Chevy Cavalier Z24 5 speed
Old 07-30-2008, 09:23 PM
j cAT j cAT is offline
Re: Rear End Questions
It is an old vehicle but some one at your local scrap yard may have this part and also have the information you need to swap out the one wheel drive for the very limited slip diff,,,I don't think it's worth it...though..
Old 07-30-2008, 09:36 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You're going to have a 7.5" axle. Whether or not you have a Series I or Series II carrier depends on the gear ratio - generally 2.73 and numerically higher use the Series II while numerically lower use the Series I. Make sure you have the right carrier! Spline count will be standard for a 1985 7.5". I am not sure what that is at this point. It will be a 10 bolt - although this refers to the bolt count on ring to carrier, this is generally the same as the cover bolt count.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
