Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 07-30-2008, 07:52 PM
bighops2000 bighops2000 is offline
Send a message via AIM to bighops2000 Send a message via Yahoo to bighops2000
Code P1406 on 97 Passport/Rodeo
1 month ago had P1406 so I replaced the EGR just to get it over with rather than spending hours on end cleaning and applying band-aids to it. once I replaced this the light was off for week. Only this time the crazy light is saying P0401. So I cleaned all in the throttle body and made sure there was a clear path from EGR housing to interior of throttle body. I even gave the inside a good scrubing with sea foam. Of course light went off but now the crazy thing is saying P1406. I really don't wanna tke it to the dea..... I can't even bring myself to say it but this light has to go. ANY IDEAS?
Old 08-01-2008, 10:17 PM
chaswe75 chaswe75 is offline
Re: Code P1406 on 97 Passport/Rodeo
Sounds like a similar issue I've had with my '96 except O2 and EGR. There are some other components that are part of the EGR system. Check your electrical connections. You will have to run a certain number of consistent drive cycles also (not to clear the code)
Conditions for Setting the DTC
  • Ignition voltage is between 11 and 16 volts.
  • EGR feedback is less than 0.10 volt at any time for more than 5 seconds.
-OR-
  • The desired EGR position is commanded to 0% and EGR feedback is 0.20 volt greater or less than the EGR closed valve pintle position for more than 5 seconds.
-OR-
  • The EGR position is not changing more than 3% in 5 seconds.
  • The desired EGR position is commanded above 0%, and the actual EGR position is 15% greater or less than the desired EGR position for more than 5 seconds.
Action Taken When the DTC Sets
  • The PCM will illuminate the malfunction indicator lamp (MIL) after the second consecutive trip in which the fault is detected.
  • The PCM will store conditions which were present when the DTC was set as Freeze Frame and in the Failure Records data.
Conditions for Clearing the MIL/DTC
  • The PCM will turn the MIL "OFF" on the third consecutive trip cycle during which the diagnostic has been run and the fault condition is no longer present.
  • A history DTC P1406 will clear after 40 consecutive warm-up cycles have occurred without a fault.
  • DTC P1406 can be cleared by using the scan tool "Clear Info" function or by disconnecting the PCM battery feed.
Old 08-03-2008, 10:17 AM
FL 3.2L FL 3.2L is offline
Have you removed and cleaned out the EGR tube?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 08-06-2008, 08:09 AM
-OR-
-OR-
??????? I've checked the flux capacitor and it looks ok???????
BTW yes I have cleared all the passages with deep creep.
My car is not "raggedy"....it just needs a lot of "minor" work....
Old 08-06-2008, 12:15 PM
Easy buddy. No one called your truck a jalopy. We are trying to help you. I did have an EGR code come up on my '96 (I think it was not functioning code) due to a post-cat O2 being removed. Also on that bank or side, my catalytic converter was below efficiency standards. Check those, just a thought.
Old 08-06-2008, 12:32 PM
I'm just playin. That was a joke since I have no clue what you were talking about in the post. PLus I wouldnt seriously call it a jalopy since everyone reading this probably has one. I'll try that though
Old 08-06-2008, 03:23 PM
You trying to call my Rodeo a P of S? HUH?HUH?
OK I was kidding too. I've owned my piece for about two months now and I have only had issues with the EGR, O2, and cattys (just emissions) It has 160k on it and runs like a beast. I am curious what brand EGR did you put on yours? This vehicle seems to very particular with parts. I used a Delphi EGR.
Old 08-06-2008, 03:35 PM
not sure it was at autozone. thought that maybe this was the problem......I regret this because in pulling out an old receipt, I found my dad (used to be his car) purchased an egr and installation from the dealer 4 years ago. THE PART WAS ALMOST THE SAME AS WHAT I PAID FOR THE KNOCK-OFF BRAND! (I paid $139 for the part and gasket. dealer was $150 for the part and the gasket was an additional $8) BTW installation was $150....and to simply clean the egr port at the dealer, it's $164 plus tax.
Old 08-06-2008, 05:27 PM
Did you ever clear the code by either disconnecting the battery for 30 mins. or pulling the PCM or ECM fuse located in the fuse box on R side(passenger) under hood?
Old 08-06-2008, 05:30 PM
If so, you should probably try and buy another one to verify the integrity of the part you have installed. I found mine on ebay for $60.
Old 08-06-2008, 09:37 PM
sure did and i went off. 2 days later.......... the part did come w/ a lifetime warranty from az
Old 08-07-2008, 12:48 AM
Take it back and try a new one. For emissions codes to clear sometimes, you will need to run what is called a drive cycle. This runs a diagnostic of several systems in order verify they are ready. This is necessary to prepare for an emissions test. Google drive cycles and you should get a generic or some other usable directions for the test. I am still dealing with that right now. I did the EGR, O2, and now 1 cat. The emissions test is showing not ready for some of these systems. Its a bitch and I am over it. Registration is expired and the DMV won't extend it. In a nut shell, you may clear the code but it may return due to the formentioned. If nothing else works, take to a pro.
Cheers
