Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-29-2008, 10:08 PM
Chantz Chantz is offline
Differential Headache
So after investigating a suspicious oil trail, we were told by a mechanic that our rear diff on our 1989 Chevy Suburban 1500 is on its way out. One from a wrecker is expensive, and we had another guy bow out on us. I've got a friend with a diff, but I have no idea what the ratio is on our diff. It is a GT4, and I'm looking at getting some friends to help replace it my own damn self.
If someone would be kind enough to tell me what ratio I'm looking for, as well as anything I should know in advance, it would be greatly appreciated. This thing is one step away from being scrapped, and I want to save it. Thanks!
1989 Chevrolet Suburban R1500
350 TBI V8 w/ 700R4
4 Wheel Drive
326 000 kms and going strong
Old 07-30-2008, 09:09 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Differential Headache
4W You need to check what ratio it has and replace it with the same ratio.
Best to pull inspection plates and read the gear rato off of the ring gear.
Good Luck
MT
MT
Old 08-12-2008, 02:48 AM
exwldr exwldr is offline
take of the diff. cover count the teeth on the ring gear &the teeth on the pinion. to tell the ratio.determine how many times the pinion has to turn before the ring gear makes one full revolution thats your ratio. on a 3:42 ratio axle the pinion turns almost 3and 1/2 times to the ring gears one revolution. exwldr.......
Old 08-12-2008, 03:50 AM
72chevelleOhio 72chevelleOhio is offline
I think gt4 is 3.73 ratio. So if it has not been messed with before, it should be 3.73..
I have been looking for a gu6 ratio (3.42) for my Z71 pick up off and on.
Good luck, I hear the carriers break easily. Which is probably why I havent stumbled across one for mine yet....
