Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 07-29-2008, 02:28 PM
kevinm0131 kevinm0131 is offline
02 Rendezvous no high speed on blower
Hi all,
I have an '02 'vous that we bought new and have been very happy with. The problem I'm having is that I have no high speed (5) on the blower, 1-4 work fine. Initially, it would work sometimes and sometimes not, now it does not work at all. I have read about people having only the high speed, but none of the lower speeds and the blower resistor pack was the fix for that. Does anyone know if that might be my problem?
Thanx,
Kevin
Old 10-01-2008, 08:15 PM
MauiMouse MauiMouse is offline
Re: 02 Rendezvous no high speed on blower
Hi,
I have an 05 Rendezvous and the blower doesn't work on the 1st speed. Sometimes it doesn't work on number 2 either. So I know your pain. They said that there was nothing wrong too.
Old 10-02-2008, 06:18 AM
jrozanc's Avatar
jrozanc jrozanc is offline
I had a 2000 olds alero with the same problem. In the alero it's a common fix to go through. My 02 Rendezvous with 104k has not had this problem yet...knock on wood. I would suspect that it is your blower resistor. It was a cheap ($14) fix in the alero and easy enough that I could do it myself.
Old 10-02-2008, 07:16 PM
oneav8or oneav8or is offline
Same here, 02 Rendezvous with no high speed on blower. Looked around online to find a resistor and where it is located to replace it, but have had zero luck. Hoping someone will post here that has been able to fix this problem.
2002 BMW 325ci, 1999 Chevrolet Blazer LS, 2004 Buick Rendezvous , 1991 Kawasaki Ninja ZX-6
Old 10-07-2008, 02:42 PM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
If the blower motor resister assembly goes bad, you should be losing first the low speed (1) then one by one the others go away (2-4). In the case of only losing speed 5 I would be more suspect of the HVAC cluster being bad (or having connection issues, try whacking on it to see if it starts working)
Old 10-30-2008, 02:00 PM
Hmm, okay thanks Chameleon, I will try that and check the connections.
Old 12-22-2008, 11:06 AM
tandr2 tandr2 is offline
Send a message via MSN to tandr2
We also have an '02 Rendezvous and over a short period of time lost fan speeds 1-3 as well as 5. Now we only have 4 and even that is not working well. I live in Manitoba where as I type this the temp with the windchill is -38. I will be replacing the resistor and hopefully that fixes it.
thanks everyone!
Old 12-23-2008, 12:46 PM
O.C.D.'s Avatar
O.C.D. O.C.D. is offline
Yesterday my blower would not work at all in my 2003, I turned on the recycled air button and it worked, I got heat. I have not driven today so I don't know if that was a fluke, but that was the first time I had to do that.
Old 12-23-2008, 12:50 PM
thanks everyone!
ok, so i picked up the resistor...$51 cdn at napa autoparts. I haven't looked too hard, but any idea where it goes? It was dark when I got home, but I looked and could not see anything.
Old 01-15-2009, 04:37 PM
gluclose gluclose is offline
Cool Re: 02 Rendezvous no high speed on blower
you need to replace your blower relay, it bypasses the resistor if it is on the highest setting so its not that.
Old 01-15-2009, 06:36 PM
I have fan speed 4 but that's not my biggest worry now - looks like both headgaskets are gone...so right now it's sitting in the driveway.
