Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 07-29-2008, 09:23 AM
lovely_laura_01 lovely_laura_01 is offline
ABS light on 1997 E350
How can i turn the ABS light off on my 1997 E-350 Truck??
Does anyone know any tricks??
THANKS!!
Old 07-30-2008, 02:38 PM
Cgroh89 Cgroh89 is offline
Re: ABS light on 1997 E350
Did you check your computer for codes on why the lamp is on? Normally it is just a sensor issue that can be resolved easliy rather than trying to get rid of the light and inhibiting the abs system
Old 07-30-2008, 03:12 PM
rhandwor rhandwor is offline
You will have to buy an ABS scanner and fix the problem or go to a shop with an ABS scanner. The cheapest that will only give codes is $200.00. on ebay.
http://www.ntxtools.com/ OTC3670HD After you click on the link type the number in search. This is a good mechanic quality tool.
I'm sure this isn't what you want to here. You maybe lucky and have a blown fuse this you can check. You can look for the wire to the sensor to each wheel and check if its broken. Some times a ring on the wheel comes off and will cause a light. Normally you can here this. The unit itself they sell rebuilt do a google search a lot cheaper than the dealer.
Old 08-19-2008, 09:29 PM
iselinzilla iselinzilla is offline
Call around to the auto parts places and see if they will test it for free. Autozone will, but they use different names in different parts of the country. Cheapo OBD2 scanners won't pick up the code, but they can reset it. If there is indeed a fault, though, it will be right back on whenever you start the truck again.
Personally, I'd find out why it's on, then try to fix the problem. Just disabling it is kind of sloppy and your truck deserves better. You may even find out it is a cheap fix.
Old 08-30-2008, 10:12 PM
knelleken knelleken is offline
take the light out of the cluster. but by the time you have achieved that, you could have actually fixed the problem that caused the light to come on in the first place. then maybe your brakes wont spontaneously lock up on you when you least expect it.
