Old 07-29-2008, 08:19 AM
metalbeast metalbeast is offline
Coolant Tube O-Ring
I had my Geo back together this past weekend. I filled it up with coolant & left it setting from Saturday til yesterday. I noticed yesterday that a coolant was leaking directly below where the tube goes into the block. It had leaked 3/4 of the coolant out of the reservoir just sitting.
I did not replace the old O-ring. I reused it. It LOOKED OK but it was less elastic than the new O-ring I just got. I have not installed it yet. Is it always necessary to replace that ring when it is removed? Is there anything that needs to be put on the new ring before I install it like a silicone grease?
ANY INFO IS APPRECIATED
1997 Camaro Z28 M6
1997 Mustang Cobra Build #6158
1991 Mustang GT M5
1993 Geo Metro LSi M5 (El Pollo!)
1995 Ford Ranger M5 (Ole' Bess, 311K )
http://musclecarevolution.com
Old 07-29-2008, 11:55 AM
bigsmellyman's Avatar
bigsmellyman bigsmellyman is offline
Re: Coolant Tube O-Ring
The O-ring will slide into the water pump easier if you wet it with coolant first.
Old 07-29-2008, 06:08 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
I use a little vaseline to make mine go in
Seriously, it works great for O-rings. I just changed mine about a month ago. There is the bolt at the trans holding the tube and another one hidden under the intake holding the tube in place.
Old 07-30-2008, 06:31 AM
Thanks Johnny! And thanks again for the parts
I put the new ring on last night & it STILL leaks I think the O-ring is too small. What is the correct o-ring size? The one that I took off MAY have been to small to begin with. This car is very frustrating. It seems NO ONE keeps parts for them.
ANYONE KNOW THE EXACT O-RING SIZE???? Thanks as always folks.
1997 Camaro Z28 M6
1991 Mustang GT M5
Old 07-30-2008, 08:16 AM
woodmen's Avatar
woodmen woodmen is offline
I just rebuilt my 95 1.0 and have a leak somewhere also. Some o-rings came in the gasket set, the old one was way to loose and swolen . The new one apeared to be same thicknes. Mine is driping of the cat. converter.
Could the mounting brackets get slightly bent and keep the tube from seating all the way into the water pump?
Sure is a strange set-up.
My avatar is a wood boat I made with a 650 kawasaki jetski .
http://s147.photobucket.com/albums/r...os/TNT%20boat/
The closer one comes to the truth, the more he is approached by a lie infowars.com
Old 07-30-2008, 08:30 AM
Maybe. I bought another O-ring that has the same inner diameter but is thicker. I hope this fits better. Mine is a very small drip.
1997 Camaro Z28 M6
1991 Mustang GT M5
Old 07-30-2008, 07:12 PM
I got an O-ring from a standard shop O-ring kit. I made sure it fit snug and was fat enough to seal. Sometimes you can take an O-ring to a parts store and have them match one up for you.
