Old 07-28-2008, 10:33 PM
Donlaw Donlaw is offline
2000 Caravan Electrical
I have a 2000 Dodge Caravan. When started the Instrument cluster lights up and shows the mileage and false tach and gas readings then they all go dead. When in power only mode withoust van running the gear indicator works as does the mileage but shuts down once van started. The panel with AC/rear wiper/temp control has no power( no lights come on whatsoever). My autodoor locks no longer lock when i hit the required speed. My remote locks work only if van is NOT running,( started it in mid January and locked it to warm up and couldnt get in). I have changed the BCM twice as well as the Instrument cluster panel and the Computer under the hood, All fuses have been check multiple times. I bought a manuel and most seem to trace a common ground (black/w light green) but it goes to the ground block panel and nothing seems amiss.
Just wanted to add that it started when the van was parked outside all day at -24c, Started fine but lost the instruments. They would come back on every so often for a week then total lose.
Old 07-29-2008, 02:40 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2000 Caravan Electrical
Sounds like a far from usual Chrysler Collision Detection (CCD) multyplex dat bus problem. Read through this thread and pay particular attention to posts #23 and 24: http://www.automotiveforums.com/vbul...ht=1996+gauges
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 07-29-2008, 11:51 AM
jpb53 jpb53 is offline
Have you checked the black with orge tracer coming out of ignition switch. Do you have voltage out of switch in run position? Look at the wiring diagram in the online service manual.
Old 07-29-2008, 06:18 PM
Just unplugged the AC control module from the dash and everything else functions proporly again. Now to get a replacement which wont be a prob. TYVM for the help, alot of relief here.
Old 07-29-2008, 06:47 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Glad to hear you're making progress. Make sure the contacts on the connectors look good. You may just need to use a little electrical contact cleaner. FYI this is only the third time I've read of the climate control panel causing your issues. Your detailed post pointed me right to it. If you get a new panel please let us know the final results.
