Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-28-2008, 06:55 PM
CNJR CNJR is offline
Question Cuts Out !!!!!!!!!! help
i have a 95 ss it cuts out when i'am driving . i hook'd up a fuel gauge to check pressure that was good. i will take off ( either light & easy or hard ) and the car will accelerate then cut right out in 2 seconds after i let of the gas it will pick back up over and over it even does it when i'am doing 70??? any insite thanks alot
Old 07-28-2008, 09:34 PM
j cAT j cAT is offline
Re: Cuts Out !!!!!!!!!! help
It would be helpful if you give vehicle history repairs mileage etc...how long you owned ....fuel filter replaced recently....DTC's??? modifications ??
check air ducting for security to intake....possible distributor coil connections and maybe the opti/plugs/wires... dies under load ??
Old 07-29-2008, 04:21 PM
Lush696 Lush696 is offline
Don't rule out an electrical short;
Reading through the past threads a very common
problem on these is at the junction box in the
right rear portion of the engine compartment;
The hot lead junctions there - check loose/corroded;
Not only can it cut out but it can also overheat,
melt your box and/or catch fire in an extreme
case; GM issued a service bulletin on this;
-Mike
