Old 07-28-2008, 11:33 AM
gm_classic's Avatar
gm_classic gm_classic is offline
timing set nut size
Those anyone know what socket is needed to pull the camshaft sprocket nut off of a 93' lesabre??? Sometimes I wish I were too dumb to attempt fixing my own car, and smart enough to make enough money to pay a mechanic.
Old 07-28-2008, 07:35 PM
maxwedge maxwedge is offline
A990 racer
Re: timing set nut size
Do you have it apart? Should be 15mm, not positive though, what is the problem, fit a socket when it is disassembled.
Old 07-29-2008, 05:35 AM
gm_classic's Avatar
I tried a 1 1/16" socket and it was to small
Old 07-29-2008, 09:18 AM
A990 racer
Ok, didn't realize that it was that large, measure the bolt with a caliper and convert to metric then buy or borrow a socket. Divide the fractional size, say it is 1.25 inches, by .040, that is the metric size. Or 32MM.
Old 07-29-2008, 08:40 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
32mm sounds about right for the harmonic balancer bolt. Is that what you are trying to find a socket for? As Max said, the timing set (cam gear) bolts "should be 15mm, not positive though".
Old 07-30-2008, 09:38 AM
gm_classic's Avatar
It was a 1 1/8" socket
Can someone tell me what these pieces went to. I found them inside the timing cover.
