Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 07-28-2008, 08:25 AM
Grandpa's Aurora Grandpa's Aurora is offline
91 Explorer power steering pulley question
I've replaced my power steering pump on my 91 Explorer but have run into a bit of a problem getting the pulley onto the new pump. I can't seem to get it to stay straight when tightening down the tool for installing it. The pulley just gets crooked on the shaft. Is there a trick that I'm missing here? I've tried spraying the shaft with silicome spray with no success. Have also purchased a new pulley. It isn't the power steering pump and I cannot put the pulley on with the pump off the car because of the way Ford designed how everything bolts in. Any suggestions are most welcome.
Old 08-25-2008, 08:52 AM
Re: 91 Explorer power steering pulley question
For anyone else that runs into this problem, I ended up taking the bracket off the car to work on it. It ended up that when the pulley went on crooked it cut a small groove in the pulley and could not get past it. I smoothed it with emery cloth ande it went on fine. We live and learn....
Old 08-25-2008, 06:38 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Thank you for the follow-up and good tip!
And congratulations on the repair.
-Rod
