Old 07-27-2008, 10:19 PM
crxsi61686 crxsi61686 is offline
b18c1 overheating and injectors????
i got 2 fans and new thermostat and the water pump is good but my car wont stay in the 185 range it goes to 210+ . The water wont circulate why??? im sure the water pump is good. With the injectors they jus all of a sudden stopped wrkin. I got 1 out of 2 wires on each injector hot. the ground on the motor for the injectors is good. what could be my prob.
appreciate it.
Old 07-27-2008, 11:23 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: b18c1 overheating and injectors????
Did you properly bleed the cooling system? If you didnt get the air bubbles out you will have problems 1. The bubble could surround the pump..and they don't pump air well. 2. The air bubbles will be much hotter than the coolant, causing hot spots..which will pass by your temp sensor and read very high.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-29-2008, 09:57 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
I second that... injectors, well, switch them out for each other... find out which ones are working, make sure they're pulsing properly, and swap them for the ones that aren't working correctly... if the problem goes away on those cylinders, you probably need new injectors... if it doesn't, it's wiring or ECU.
