P28 ecm for mpfi conversion on d15?
I've got a few things I needed to get done to my car finished up and now the next thing on my list (after wheel studs) is a mpfi conversion.... what I'm wondering is if I can run the vtec p28 ecm for a d16z6 on my non vtec d15b2 as long as i have the dizzy, sensors, etc. I plan on dropping a z6 in here once i have the cash set aside and the time to do it...
Any help appreciated |
Re: P28 ecm for mpfi conversion on d15?
You would have to do a obd0-obd1 conversion and it would probably throw codes if its a stock ECM because your engine won't have everything it needs...like VTEC.
Tony 91 Civic Sedan DX - Stock 287k Miles |
He said it. Itll throw vtec solenoid codes. If you want to go obd1, and not change the head. Use a p06. Its the non vtec d15b7 ecu.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
If you just swap the ECU, you'll have injector codes, and your engine most likely won't start.... you can use a Vtec ECU on a non-Vtec engine, but you'll throw a Vtec solenoid inactive code whenever it should engage.
Best bet is to get a PM6 and do the MPFI swap, then invest in whatever you want and sell your other parts when you're ready. |
Actually on an obd1 ecu itll throw the code without ever trying to hit vtec. It just knows...
yeah, solenoid inactive code.. can't think of what it is... I've never had it happen until WOT tho.
alright thanks guys, now what i'm wondering is if i could put a z6 head on a d15 block...
Its called a Mini-me, do a search for it
The only thing I found was a z6 head on a d16 block
I'm pretty sure its the same on a d15 block. Give me a little time and I will find out. I frequent lots of boards, d-series.org is a good place for engine info
It's precisely the same, except depending on what block you use, you might need to switch to pistons with 4 valve reliefs (B8 I believe)
You also could have to either remove or drill out the oil thingy (technical term) that goes under the head in the oil passage.. it's a little removable metal thing... not sure what it's called atm. But, it acts as sort of a Metering Device so that you're keeping oil pressure, and not flooding the head with oil... which, if you're at all familiar with D-series engines, isn't a problem at all... |
well the block i'm gonna use is a good ol' d15b2
just got a mpfi intake on ebay
Found a d15b7 mini me swap:
http://www.d-series.org/forums/showthread.php?t=27126 Check Post #3 There are other useful things in there also. The d15 mini-me write up might not be exactly what all you need to do. I haven't went and read it all yet. I had actually found 2, the first one was just retarded, so i won't give you the link for it, lol.
lol thanks tony, as i said above i jus bought a z6 intake manifold, now i'll be off to the junkyard in the coming weeks for the tb, fuel rail, etc.
and hopefully find a PM6 ecm to go mpfi |
